Problem: Hello, I don’t have the optoin Exportation “Simulation Flash”, what’s the problem ? Thanks
ActivePresenter Version: 6.1.3 professoinnel
OS: W7
OS: W7
Exporting to Flash has been dropped since ActivePresenter 6.0.
That is because Flash format is not supported by many modern web browsers anymore and the HTML5 output is superior.
Thanks a lot;
Another question please, we have some files project made with Adode Captivate, it’s impossible to open with Activepresenter, have you a solution please ?
Thanks you
Unfortunately, Adobe Captivate project is a proprietary format and ActivePresenter cannot read it.
