Bonjour, je souhaite utiliser ActivePresenter sur un système disposant 3 écrans. Comment choisir l’écran sur lequel se fera la capture, par exemple au moyen de son numéro défini dans les paramètres desystème (windows 10)
By default, ActivePresenter automatically captures the main screen set in the system, for example, when you select the fullscreen mode to record.
Besides, you can record whichever screen you want by dragging and resizing the recording area (blue rectangle). For example, dragging it from screen 1 to screen 2 to record screen 2, or resizing it to record both screens 1 and 2.
Please feel free to try it yourself and let us know if you encounter any issues.
