Hi ,
Is it possible to capture a scrolling webpage and display it inhtml5 export?
Is it possible to get/display a scrolling view of a webpage ?
Thanks,
Kevin
Hi ,
Thanks,
Kevin
You cannot capture a scrolling webpage with ActivePresenter but you can embed that webpage into your HTML5 using the Web Object.
Just insert a Web Object and paste the webpage URL. That webpage will be loaded and is scrollable when the Web Object is shown.
