Problem: I try to activate an event on scroll (a video appear and start to play) but it doesn’t work.
Does someone can help me?
Thank you.
Saola Animate version: 2.03
OS: windows 10
Thank you.
OS: windows 10
Scroll event only occurs if there’s elements overflow the scene boundary, and the scene’s overflow property is set to scroll or auto.
Moreover, the scroll event can fire multiple times at a high rate when you scroll the scene. So you usually need to write script to show and play the video once on the first scroll event.
Hello,
Thank you for your answer.
So there is no way to play and pause a video when it is in the viewport or not without coding?
Thank you.
Regards.
Boris.
Yes, unfortunately there’s no way without coding.
