I set my screen preferences, project size, 24001347 (fits my monitor)
Recording settings the same 24001347
Start recording and a popup appears saying, ‘The recording size is different from the project size. Do you want to continue?’
I continue, when I finish recording the capture is smaller with black edges on two sides.
I go to Design and then to slide size, I set the preset size as 2400*1347 then ok, does nothing, can you please help me
Most of video codecs require that the width & height resolution must be even numbers. So to avoid errors when encoding the video, ActivePresenter automatically just width & height of recording area to the closest even number.
Your screen height (1347) is an odd number! Please avoid creating project size with odd width or height.
Thank you I’ll try that
