With upgrade that came out yesterday I am having an issue when recording my screen. No matter what I select in the custom box it always seems to record some where else and then a much smaller section. It isnt close to what I have selected in the box
ActivePresenter Version: Version 8.0.4 (Released: 2020.03.25)
OS: Windows 10
I did not have this problem with the previous version.
If you are using multiple monitors, please make sure they have a same scaling setting (DPI) since ActivePresenter recording function doesn’t work well with multiple monitors which have different scaling settings.
If you are using custom scaling, please switch to either 100%, 125%, 150%, 175%, 200%… to see if it works.
