Can we make scratch animation like this, which can work in both mobile and desktop http://once.pl/anim/scratch/
Hi Niraj,
Saola Animate supports adding custom JavaScript, so the answer is yes if you have or you can write the script to do that.
You can also use a HTML Widget element to embed another web page that has scratch animation.
