Problem: I have created a Drag-N-Drop question with 10 answers. When I publish via HTML5, it works correctly. When I publish to SCORM, Experience API, or LMS, it freezes when the Submit button is pressed.
Could you please tell us which LMS you are using?
Besides, it would be helpful if you can share your project so we can further investigate this issue.
Please be aware that if the video or audio resources exceed 50MB, the project will generate an external data folder named PROJECT_FILE_files. Please include that folder (if any) along with your project when you send it to us.
You can email us at: support@atomisystems.com
I am using Desire2Learn but I also put it in the SCORM Viewer at Rustici to see if it was just the LMS having issues with it. It froze in the SCORM Viewer as well. I was going to upload my project here but it won’t let me so I’ll email you.
