Notes: When you add to the project captions, you have to set for them a fixed scale. Can I set it on auto somehow, for when I export it to html, then when the video is scaling to fit to the window size (btw I managed to set this scaling using your advices on this site), captions stay the same size all the time. Can I change them to fit to to the window as well?
Are use creating a non-responsive project (normal project) or a responsive one? In a normal project, closed captions will be scaled at the same ratio as the other content. Can you please provide a screenshot so we can understand the problem exactly?
Hmm, I didnt know this was the case, but I am using responsive project in fact. I will try to transform it to non-responsive and will let you know if the problem still occurs.
