Is there a way to have the same font size when using on mobile? It takes some font settings from the browser.
I keep getting different font sizes according to the user browser settings and its no good.
It would be helpful if you can share project having the issue and its external data folder named in the PROJECT_FILE_files(if any) to support@atomisystems.com so that we can check.
If these files are large, you can upload them to a cloud storage site like Google Drive then send the download link to us.
