Active presenter 8 Windows 10
I have a responsive project, which is a slide, with an image of a certificate, over which I have boxes which will display dynamic data. I need for the boxes to remain over the same areas of the image in order for it to print nicely.
Can you have an anchor point assigned to another object and your other objects remain at distances X and Y from that anchor in all different responsive sizes?
Just simple grouping doesn’t work.
