Someone else did the software screen recording. When I download the file .appoj
I don’t end up with audio.
error message
resource file not found - 10449_Audio_450.wav
active presenter log
2019-08-20 15:36:22: ActivePresenter 7.5.8 (Release Build: 2019.06.27) started
OS: Windows 10 (build 15063), 64-bit edition. Version: 10.0 - 64 bit
CPU Count: 4
Hostname: L0MN000108122.int.carlsonwagonlit.com. Memory: 8,072 MB. Available: 3,486 MB. Memory Load: 56%
Project Location: C:\Users\u027txt\Documents\ActivePresenter
Disk Space: 243,596 MB (Free: 109,259 MB)
2019-08-20 15:36:22: TempDir: C:\Users\u027txt\AppData\Roaming\ActivePresenter\temp
2019-08-20 15:36:25: PrepareRibbonBar: 1253ms
2019-08-20 15:36:26: Opening project: C:\Users\u027txt\Downloads\Mcrossinfo.approj
2019-08-20 15:36:27: Warning: Resource file not found: C:\Users\u027txt\Downloads\Mcrossinfo_files\10224_Audio_225.wav
2019-08-20 15:36:27: Warning: Resource file not found: C:\Users\u027txt\Downloads\Mcrossinfo_files\10449_Audio_450.wav
2019-08-20 15:39:21: Opening project: C:\Users\u027txt\Desktop\tiff notes\019 tt projects 2019\02_GT 2019\Draft training docs GT Counselor\026 Meeting Profile\Todd take543.approj
2019-08-20 15:39:22: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2019-08-20 15:39:22: Audio Decoding Stats: Process 16.000000, Wait 2.000000
2019-08-20 15:39:22: Audio Encoding Stats: Process 7.000000, Wait 22.000000
2019-08-20 15:39:22: Audio Decoding Stats: Process 17.000000, Wait 0.000000
2019-08-20 15:39:22: Audio Encoding Stats: Process 8.000000, Wait 12.000000
2019-08-20 15:39:31: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2019-08-20 15:39:31: Audio Decoding Stats: Process 9.000000, Wait 13.000000
2019-08-20 15:39:31: Audio Encoding Stats: Process 16.000000, Wait 2.000000
2019-08-20 15:39:43: Opening project: C:\Users\u027txt\Documents\ActivePresenter\8 15 test.approj
2019-08-20 15:39:43: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2019-08-20 15:39:43: Audio Decoding Stats: Process 68.000000, Wait 0.000000
2019-08-20 15:39:43: Audio Encoding Stats: Process 46.000000, Wait 28.000000
2019-08-20 15:40:07: Opening project: C:\Users\u027txt\Downloads\Mcrossinfo (1).approj
2019-08-20 15:40:07: Warning: Resource file not found: C:\Users\u027txt\Downloads\Mcrossinfo (1)_files\10224_Audio_225.wav
2019-08-20 15:40:07: Warning: Resource file not found: C:\Users\u027txt\Downloads\Mcrossinfo (1)_files\10449_Audio_450.wav
2019-08-20 15:49:30: Opening project: C:\Users\u027txt\Downloads\Mcrossinfo (2).approj
2019-08-20 15:49:30: Warning: Resource file not found: C:\Users\u027txt\Downloads\Mcrossinfo (2)_files\10224_Audio_225.wav
2019-08-20 15:49:30: Warning: Resource file not found: C:\Users\u027txt\Downloads\Mcrossinfo (2)_files\10449_Audio_450.wav
ActivePresenter Version: 7.5.8 free version
OS: windows 10
