Problem: Cannot reset the interface. My timeline has moved to the right of the canvas and I can not put it back on the bottom.
Saola Animate version: 2.7.1
OS: Windows
OS: Windows
Try expanding the pane until you can see the float icon (below). Click this and the pane will float and can be moved back into position.
