Problem: I have an ActivePresenter presentation consisting of 50 slides the first 47 are Recorded Software Simulation the last three are True / False questions, is it possible to only Report on the final 3 slides ‘True/False’ questions and not the entire presentation?
ActivePresenter Version: ActivePresenter Pro Edition Version 7.5.11
Yes, you can select interactions (Mouse Click, Key Stroke, Text Box) in recorded slides, clear their Report ID check box in Properties pane > Interactivity tab > Score & Reporting section to remove them from the report.
Thanks you for the reply. I’ve now set up a template as per your instruction for future use. I also managed to workout how to remove the Report Id but I had to do it individually for each of the 47 slide.
