I’ve been working on a project where in the final version, my voice audio (a non-native speaker of the language the project is in), will be replaced by a native speaker of the language. I know in general, approj files store everything internally. I also know I can set ActivePresenter to store files externally, but the minimum size if 5 MB. At the moment I have approximately 630 audio files in the project and all of them around 10KB each. And I will likely have around 800 once the project is finished. Once I am ready to exchange my vocals with a native speaker, is there any way to swap these audio files out externally so it replaces all the instances where it’s used? Or do I have to click on each instance of their usages on every slide of the project and swap them out? For example… is there a temp file opened while my approj is open? I went into this figuring I’d have to do it all manually… so it isn’t the end of the world if I have to do so. But I’d prefer not to if there was a better way.
Hi @Da_Re,
Unfortunately, you have to replace your audio files manually.
There’s no better way with the current version of ActivePresenter (9.2.0)
Thanks for your quick response. Keep up the great work!
