Michael
(Michael)
July 23, 2018, 1:40pm
#1
Hello,
I’m trying to find a way to add a button to repeat current slide - I want to use this for the SCORM export so the user can repeat a slide when he reaches the end of it.
I added a button with an:
execute java
and then
continue presentation
The execute java is:
Prez.ShowPreviousSlide()
Prez.ShowNextSlide()
(i’m using version 6)
this works fine for all slide but the first one (as there is no previous).
Any idea how to make this work for all slides?
I tried using ShowSlide and GetSlide but the first wants an integer and the second returns an object.
Any suggestions?
Best regards and thanks in advance,
Michael
ToanLS
(Toan Le)
July 24, 2018, 1:48am
#2
Hi Michael,
For version 6, you can use the script below to repeat the current slide:
Prez.ShowSlide(Prez.Session.SlideIndex + 1);
Michael
(Michael)
July 24, 2018, 7:11am
#3
Hi Toanls,
This works perfectly - thank you so much. Great!
Also, if you could use your expertise to assist me with another problem, I would really appreciate it:
Dear all,
I’m looking to make a pause/resume button directly on the slide - so that the user can pause a presentation during a SCORM Test play. I would like to have a single button not 2 (play and separate pause).
I tried to use an execute javascript:
if(Prez.Pause() == false)
Prez.Pause(true)
else if(Prez.Pause() == true)
Prez.Pause(false)
or also
Prez.Pause(!Prez.Pause)
It stops it fine but doesn’t want to resume on second click…
Any suggestions?
Thanks in advance and be…
I’m struggling with a pause/resume button
Thanks again!
Best regards,
Michael
ToanLS
(Toan Le)
July 24, 2018, 7:45am
#4
I’ve answered that question, please check it.
Marcel
August 23, 2018, 12:19pm
#5
Hello everybody,
i have the same concern, but in AP7. Currently i am using for a custom repeat button the following code for On Click: Execute JavaScript:
prez.previousSlide(0);
prez.nextSlide(0);
I would like to use
prez.showSlideAt(currentSlideIndex(),0);
but i have no idea how to get the index number of the current slide. Could you provide me with a reasonable solution?
Many thanks in advance and BR
Marcel
dangle
(Dan Le)
August 23, 2018, 12:36pm
#6
With ActivePresenter 7, you can get current slide index via:
prez.currentSlideIndex()
The index starts from 1.
More details can be found in the User Manual page 212.
Marcel
August 23, 2018, 12:47pm
#7
Hi dangle,
thanks for the prompt reply, great support again!
I forgot the ‘prez.’ part inside the brackets. The following code works perfectly:
prez.showSlideAt(prez.currentSlideIndex());
