Problem: I have many projects started in versions 6 and 7 with many lines of javascript that reference objects such as “Text Box_” and “Fill In Multiple Blanks Question_” that have changed in version 9 to “Text Entry_” and “Fill In Text Entries Question_”, is there a way to change the way the program refers to these objects rather than editing all my javascript.
Since the version 6 and version 9 APIs are different, it is recommended to rewrite the script in this case.
With version 7 or later, please try the following workaround:
Open the ActivePresenter > Project > Properties pane.
In the Interactivity tab, in the On Load event, add an Execute JavaScript action.
Add the following code to the action:
if (prez.__inited)
return;
prez.__inited = true;
var oldObjFunc = prez.object;
prez.object = function(objName) {
var obj = oldObjFunc.call(this, objName);
if (obj)
return obj;
if (objName.startsWith("Text Box_"))
objName = objName.replace("Text Box_", "Text Entry_");
else if (objName.startsWith("Fill In Multiple Blanks Question_"))
objName = objName.replace("Fill In Multiple Blanks Question_", "Fill In Text Entries Question_");
else
return obj;
return oldObjFunc.call(this, objName);
