Is there a way to remove Text2Speech audio from practice, tutorial, and test mode? I would like this to only play in the demonstration mode.
Unfortunately, this is not supported in ActivePresenter. However, you can use separated audio objects instead. Audio object also supports generating voice from text.
I will give this a try. Thank you!
