Recording desktop screensaver only
Hi, I am trying to record a PowerPoint presentation using the Record Video option. The video recorded shows only the image on my desktop, nothing else. Help!
Can you give us some detailed information such as your environment and the app version?
Thank you for the super quick reply.
I am using the most up to date app version: ActivePresenter for macOS 8.0.7. I am using Macbook Pro Catalina 10.15.5.
Thanks for your information. Please refer to this thread Screen recording only captures background in mac to see if it helps.
I cannot thank you enough. The fix on that thread worked perfectly. Much much appreciated.
