Is there an option to rebuild slides by selecting multiple audio or video resources and “Rebuild” them to slides?
For your information, you can rebuild slides by using Resources Pane.
This pane provides you with all the resources that are available in the current project.
All you need to do is to create a new slide > View tab > click Resources > drag and drop the resources from the Resources pane into the slide.
Hope this helps solve your concern.
Kind regards,
Quynh Anh
