Radio buttons / Gift import
Problem: Radio buttons / gift import
ActivePresenter version: 8
OS: Windows 10
Hi, I’m creating a template to import gift questions. When I import the file, it perfectly creates a slide for each question. The questions contain radio buttons. I see that automatically the radio buttons are called Button_Radio_1, Button_Radio_2, Button_Radio_3, etc …
Issue:
When I change the radio button style (default is too small) from format and make it default and re-import the gift file into my template I see that all radio buttons are named the same, Button_Radio_4, Button_Radio_4, Button_Radio_4, Button_Radio_4
This is a problem because publishing the presentation and choosing to review questions shows all the options as correct.
Is there any solution?
Thanks a lot.
Thanks for reporting bug. We will try to fix it soon. We are sorry for this inconvenience.
In the case, you can follow the steps bellow:
  1. Import the gift questions.
  2. Change the radio button style from format
  3. Right-click the radio button > Apply to All Radio button Objects > Style.
For more information, please refer to this tutorial:
Perfect, for now that option may be useful.
I’ll wait for the update.
Thanks a lot and congrats for always giving and excellent support !!
Pablo
