Marie
July 16, 2022, 12:09pm
1
ActivePresenter 8.5 Pro Edition
Version 8.5.7 - 64-bit build. (Released: 2022.05.16)
OS: Windows 10
I can no longer click in the quiz boxes. Even on quizzes that were tested fine before this bug.
I also reproduced the same bug on one of your projects that I downloaded from ATOMI’s website (the Volcano project).
Also, buttons event settings don’t work anymore on both my project and the Volcano one.
I have set an on click event, but nothing happens when I click on the button, and the slides keep going even when the auto advance box is unchecked.
Any thought about this?
Thank you,
Hi Marie,
For your information, in the Demonstration mode, the task will be shown as a demonstration for learners.
Therefore, you are not supposed to interact with the content but only to view it.
You can find more information about our 4 Operation modes via the link below:
ActivePresenter allows you to run interactive presentations in four operation modes, which are Demonstration, Tutorial, Practice, and Test.
Est. reading time: 10 minutes
Hope this helps.
Kind regards,
Quynh Anh
Marie
July 18, 2022, 7:30am
3
That’s right. It works on the tutorial mode!
Thanks for your support
