Is it possible to put Drag & Drop and text entry box on same slide? If so how can this be done.
It seems that you want to add different question types to the same slide.
ActivePresenter allows achieving that with some simple steps.
Please take a look at the video below for details:
Further, check out this video if you want to insert more than 2 question types into one slide:
Have a nice day,
