I want to be able to set font and text size for an entire project so that I don’t have to change it on every text example. I don’t see it anywhere in the Preferences section.
You can do the following steps:
- Go to View > Object Settings, and select the object you need to change.
- Go to Home > change font ant text size.
Besides, you can save the project as a custom theme to reuse later.
Refer to this articles for more information:
