I’m not sure if this is a problem with ActivePresenter or not. SVG files don’t display with the correct font in ActivePresenter even though the font is installed. Also, for some SVG files in ActivePresenter, not all items are in the correct locations.
The current version (8.0.0) of ActivePresenter only supports a limited subset of SVG. If you are creating the HTML5 content, it doesn’t affect to the output, but it does for the video output.
We will try to improve SVG support in the future update.
