Problem: I’ve created a “test” out of the interactions, so that people can follow along and at the end of the test, I’ve used the Report Slide to show what they got correct and what they got wrong. However, when I took the test, the report slide is showing that I’ve gotten them all correct, but it is showing me at 81%, even though I didn’t get anything incorrect. Do you know how I could fix this?
Hi Batman,
Can you please share the project so we can check? You can email it to support@atomisystems.com
Hi Batman,
It looks like you have selected to show absolute score in the report. Please follow below steps to resolve the problem:
- Select the report.
- Go to Properties > Interactivity.
- Expand the Report Display section.
- Clear the Score option and select Percentage.
Hope this helps.
