good morning, i have a problem downloading a .hex file inside a scorm.
The problem is that when downloading the file when pressing a button
(using a java:
var a = document.createElement(“a”);
a.href = “resources/EA06_Programa_o_erro_no_sensor_N3.hex”;
a.download = “EA06_Programa_o_erro_no_sensor_N3.hex”;
a.click();
the downloaded file contains an html instead of the original (.hex)
I enclose an example project with what happens to me.
What would i be doing wrong in java?
a greeting
Description of the example project
Button 1: link in the text to the resource: It works but we don’t want to put a link in the texts
Button 2: link to the resource by opening it in the browser: It works but it is not good for us, because we must download it
Button 3: download the file but convert it to another format and it does not work for us
