I have: Animated timer over slide.
How to start the timer.
ActivePresenter doesn’t support controlling a timer that shows over multiple slides from an object in a certain slide yet. We’ll try to improve it in future releases.
In the meantime, you can set the object show over multiple slides in the same layer with the timer so that it can control the timer.
Another method is using Execute JavaScript action with the following script:
prez.object('Animated Timer_1').startTimer(); // replace Animated Timer_1 by your timer name
