When I import powerpoint file by select process object in slide, it dose not work.
It was OK with free version 6 but not the purchase version 7
Can you please be more specific about the issue? Is there any message shown up? Is there any slide imported?
Hi, thanks for reply.
There was no message shown.The number of important slides is correct but all the slides are blank and cannot be edited using AP7.
Supplement info: my office is 2007 version
Unfortunately, the minimum supported version is 2013 as described at https://atomisystems.com/activepresenter/system-requirements/. FYI, We are removing the dependency on Office in the next major version of ActivePresenter.
