Problem with Green Screen effect
Problem: Applying the green screen effect does not remove all of the green colour
ActivePresenter version: 8
OS: Windows 10
Notes: I use a green screen background, and when I try removing it using the eye dropper it only removes part of green colour and leaves some parts, why is that the case?
Hi Sterling,
Besides using the eyedropper tool, you can try dragging the Tolerance slider to adjust the range of color to key out.
You can take a look at this tutorial for more details:
Yen
