I use the Roboto font for my projects and infortunatly, the font changes itself back to arial when I export the project in HTML5.
Could you work on that problem with the next version ?
Please check if the PC on which you view your HTML5 has Roboto font installed or not.
Please select Embed Fonts when exporting to HTML5 to make sure your content looks consistent though viewers’ PCs don’t have your fonts.
If you already embedded Roboto font, or the viewer PC has this font, please share a sample project and its exported HTML5 folder so that we can check.
