Sorry!
There no “Choice” in events function in multiply choice as it was in your manual. I cant put right answer. Could you tell why it could be? Thanks
ActivePresenter Version: Free latest version
OS: Windows 8
Sorry!
OS: Windows 8
It looks like you are choosing the Survey mode for the question, so you cannot set the correct answer.
Please go to Properties pane -> General section, then select Graded.
Thank you very much! I understood! But it also does not work with TRUE/FALSE interaction. There no place where I could put what it correct TRUE or FALSE. I put GRADES but no changes.
Dmitri
You can right click on each Answer and select “Set as Correct”.
This method should work for all question types.
