In my project the audio and video are not synchronized. The audio is a little bit faster than the video. How can I solve this problem?
Windows 7
Active Presenter Free Version
Windows 7
Hi Juliana,
You can use Timeline to move the audio back a little bit to sync with the video.
Ok, Dao.
I`ll try it.
Thank you.
Stupidest question. How do you move the audio back
Hi Halmi,
In the Timeline pane, you can select an audio object then drag it back.
Alternatively, you can also press LEFT ARROW on the key board.
