Problem: On some computers preview works fine: the link uses http. (e.g. http://localhost:13536/1670922824287/demo.html). But on other computers, it fails since the link starts with https. When you remove the s (http://…) the preview works again.
Where is the behaviour defined whether the preview via localhost is using http or https? I could not find any corresponding entry in the ActivePresenter settings.
The internet options of the PC? But where?
Thanks a lot in advance for any hint,
best regards,
Martin
Hi Nam,
I can’t download the setup, it is blocked by our company firewall.
On the other hand, there must be a more generic root cause, since the same problem occurs with V8.5.1 (which is currently rolled out in our company). I realized the problem when preparing the change to V9.0.4. What else can I do?
Hello,
It worked for one of the test PCs. I have to test it with the others, too. But they are not available before Monday.
Thanks a lot for your quick support.
Best regards,
Martin
