How is it possible to import powerpoint speaker notes ?
Could it be copied into the slide description ?
Or do we have to make a macro for that purpose ?
Hi Serge,
Unfortunately, the current version of ActivePresenter hasn’t supported the speaker notes feature.
Yen
Just to give some support as a new feature. It would be great if notes in powerpoint are directly imported as text box during sound narration. I tend to put in Speakers Notes what I will say and it would make it really powerful if there is an option when importing to directly import them. This would make narration even easier. Awesome program as always.
Hi Ferenc,
Thank you for your suggestion.
Importing PowerPoint notes into ActivePresenter has been added in our to-do list.
Yen
