Poor quality of imported audio
Hello. I’m using AP 9.3.0, have both mp3 and wav files with sound quality as I want it (edited first in Audacity to get it right). After importing into AP on a slide, the playback volume is drastically reduced. Is there anything I can adjust in AP settings to improve this?
Thanks.
Ian
Could you please share your original MP3 and WAV files, as well as the edited files in Audacity, so we can investigate further.
If these files are large, you can upload them to a cloud storage site like Google Drive, then send the download link to support@atomisystems.com.
Best regards,
Hi. Thanks for getting back to me. For now I’ve gotten round the issue by amplifying the sound in Audacity then re-importing. The result is good enough for my current purposes so there’s no need for you to spend time investigating it. But thanks for getting back to me.
Ian
Glad to know that you resolved the issue yourself.
Have a nice day.
BR,
Just for others’ benefit, I’ve noticed that if I import an mp3 then the volume in AP is lower than the original mp3. Whereas if I import a wav file the volume remains the same in AP as in the original file.
Ian
