Hello,
On my last slide I would like to play a 15 seconds audio clip - problems is that if users leaves the presentation before the end of the slide - the SCORM will not be marked as complete.
Therefore I’m using adjust variable apCmdEnd to complete the module on load of slide… buttons and hyperlinks still work after that but I cannot play the audio…
I tried attached to an object
I tried attached to an object and show object command.
I tried play audio command.
Is there a way I can play an audio after apCmdEnd?
Thanks,
Michael
