Hi people
I try to use the navigation in the modern player of AP8, to save me some screen estate. Slides are created in resolution 1280x720, trying to keep things responsive. Unfortunately, this always leads to a top-down scrollbar after uploading a SCORM to an LMS. The viewport on screen is 1920x1080 and higher resolutions are acting the same.
What’s your approach on using the player or do you mostly prefer on screen navigation?
