Is it possible to place a pause on the timeline without an event to trigger it?
ActivePresenter Version: Required.
OS: Required.
OS: Required.
Do you mean that you want to pause your presentation without user interaction?
If so, you can insert an Animated Timer, then add On Timer Complete event to pause the presentation after the timer stops counting.
For more details, please take a look at this tutorial:
