Is there a way to pause the timeline after an object entrance effect?
Thanks
Thanks
Hi Dom,
Unfortunately, there is no official feature in ActivePresenter for you to do that. But you can add an Animated Timer at which the effect ends as a workaround. Please see the attached project for more information. pause timeline.approj (212 KB)
Hang
I already use this workaround, but it is pretty tedious if you have to use a lot.
The availability go keyframes would be great!
Thank you.
Hi Dom,
Thanks for your feedback. We will try to improve this in the future release.
