Problem: When you create object templates and then you save the file and move to another machine (both are PC’s) object templates are gone. That shouldn’t be this way I guess. There is no way to collaborate between 2 editors.
ActivePresenter Version: Required. 7.5.13
OS: Required. Windows 10, 64 bit
Hi Tomasz,
Please make sure to save your object template folder (in both PC) in ActivePresenter Templates folder:
You can take a look at the tutorial Create and Use Object Template for more information:
Best regards, Thuy
Thanks a lot. It was very handy.
