Object templates and themes
I know how to save and re-use themes and object templates.
Is there a way to store a set of object templates together with a theme so that the user only has to load a theme and will automatically have the object templates that go with that theme without having to store the template file in the relevant folder on his computer?
Thanks,
Rolf
Hi Rolf,
For your information, it is not possible to do that in the current version of ActivePresenter.
The object templates will be saved separately with a theme since they can be used across projects.
But you can consider doing the following way to see if it helps.
Then, when you open and work with your custom theme, you will see its specific objects.
This may allow you to show each theme with specific objects instead of saving too many sets of object templates.
Hope it helps.
