It would be great if I could set object states for a group.
The is a conflicts in implementation since each object in a group also has its own states. We will take a note on this feature request and try to fingure out the solution for this.
I think maybe objects in a group should be treated as a single object and then the state is only configurable for the group as a whole. This way you can just create multiple group states and ignore the states of each object, but still giving the ability to edit each object in the group within each group state.
