If I don’t use the scorm reporting function, the controls on the player won’t work.
Is this something you can fix please?
ActivePresenter Version: 7.01
OS: Win 7
Doesn’t seem to matter what browser I use.
OS: Win 7
Hi Matthew,
By default, pause/resume and slide navigation using toolbar or ToC will be disabled in Test mode. You can enable it by taking the following steps:
Regards.
Thank you. Sorry, I thought if I could see it then it would work.
