Problem: Not able to use microphone of Logitech HD pro Webcam C920
ActivePresenter version: 8.0
OS: Windows 10
2021-11-05 11:23:32: Failed to open audio stream to record. Error: Invalid device.
2021-11-05 11:23:32: Preparing to record audio from: Microphone (HD Pro Webcam C920). Channel: 2. Sample rate: 32000. Sample Format: 8
2021-11-05 11:23:32: Probing audio device for recording. Error: Invalid device. Retrying with default parameters
2021-11-05 11:23:32: flt sample format is not supported, s16 will be used
2021-11-05 11:23:32: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
Could you upgrade to the latest version (8.5.3) and try again?
If the issue persists, please send us the full log file via support@atomisystems.com so we can take a look.
Thanks for your response. I tried all three options . It did not work. Audio works if I choose Microsoft array, which is in built audio. HD Pro audio does not work. HD Pro Microphone works with software like Microsoft Team, Zoom etc.
