Thank you for your feedback!
It is coincident that Javier has just found out that too! Couldn’t think that would cause the issue, unbelieveable!
We’re digging deeper into this and will try to fix.
Best Regards,
Best Regards,
Hi all,
We’ve finally found out what causes the issue and fixed it thanks to your valuable feedback!
To summarize, this issue happens when both of below conditions are met:
None of us use auto-hide taskbar so have never experienced the issue.
A quick workaround is to turn off auto-hide mode of the taskbar.
We will release an update in a few more days.
Again, thank you very much!
Dang.
Latest version, 1.02, fixes this issue. Well done Atomi!
