Hello,
I downloaded this project: Wildlife - Menu Template.
When I view it on https://atomisystems.com/project/wildlife/, I notice that there is no viewer and there is no automatic advance.
When I open it with the software, I do not see how to do that.
Thank you for your help.
There is a button in Title Layout in Slide Master which has a “Pause presentation to wait for user input” option. Therefore, the presentation will pause at the end of each slide.
ActivePresenter 7.5 has a new “Auto Advance” option, so you don’t need use that trick. You can remove that button and uncheck “Auto Advance” option for each slide.
