I have been using Active presenter for some time. I had no problems. But one day, my new recordings started being with no voice. You can hear mouse clicks but not my voice. I have reinstalled the application and I have restarted PC several times. I went to see the log and I am pasting it here below. I have checked the microphone settings. To my opinion they seem to be fine.
2017-07-05 14:47:31: flt sample format is not supported, s16 will be used
2017-07-05 14:47:31: Preparing to record audio from: Microphone Array (Realtek High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2017-07-05 14:47:33: Start capturing. Mode: Full motion. Method: 0. Capture Size: (3840, 2160)
2017-07-05 14:47:33: Video Codec: flashsv. Expecting FPS: 30.00
2017-07-05 14:47:33: Video will be recorded to: C:\Users\Egle\AppData\Roaming\ActivePresenter\temp\rl_20170705_144733_4yp18wfuws_tempdir\video_20170705_14-47-33.mkv
2017-07-05 14:47:33: flt sample format is not supported, s16 will be used
2017-07-05 14:47:33: Audio will be recorded to: C:\Users\Egle\AppData\Roaming\ActivePresenter\temp\rl_20170705_144733_4yp18wfuws_tempdir\audio_20170705_14-47-33.wav
2017-07-05 14:47:33: Preparing to record audio from: Microphone Array (Realtek High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2017-07-05 14:47:33: Audio 2 will be recorded to: C:\Users\Egle\AppData\Roaming\ActivePresenter\temp\rl_20170705_144733_4yp18wfuws_tempdir\audio_20170705_14-47-33_1.wav
2017-07-05 14:47:33: Preparing to record audio from: Speaker/HP (Realtek High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2017-07-05 14:47:42: RLMedia: Estimating duration from bitrate, this may be inaccurate
2017-07-05 14:47:41: Stop video recording. Frames recorded: 62. Dropped: 0. Duration: 5241. Actual FPS: 11.64
2017-07-05 14:47:42: Recorded video data size: 2883 KB
2017-07-05 14:47:42: ProcessRecordedAudio: duration (ms) 5366.896000
2017-07-05 14:47:42: ProcessRecordedAudio: duration (ms) 5482.604000
2017-07-05 14:47:47: Preparing to play audio to: Speaker/HP (Realtek High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2017-07-05 14:47:47: RLMedia: Estimating duration from bitrate, this may be inaccurate
Please let me know what I should check further to restore the voice recordings.
I facing the issue for more than a week. I also can’t see any audio wave or even audio saved. the audio bar is white not even gray like the slide. I was using the program very well on windows 7 but when i upgraded to windows 10, I facing this issue. The program sometimes record and sometimes not. Which is very weird. I tried to record on another programs and they are working very well. I also installed the latest version that was issued 2 days ago but still facing the same issue. I also cleared the older folder and cleaned any cache.
Can you please install the latest device driver for your audio device using the driver from the hardware manufacturer instead of the default driver which comes with Win 10?
