since last update I have no more audio options in the recording screen.
The only available option that now I see is for the microphone (grayed out) that anyway I can’t enable.
ActivePresenter version: 8.5.7
OS: Windows 10 64bit
Hi Andrea,
To clarify the problem, can you please send us the log so we can check?
To view the log:
You can follow the guiding steps through this video:
https://www.youtube.com/watch?v=qdt7Z5h5bVc&t=3s
After that, kindly send the log file to the email support@atomisystems.com
Best Regards,
Huyen
Hi Huyen, thanks for your reply.
I’m trying to attach the log but, as I’m a new users, I’m not enabled to it.
Is it ok if I copy/paste the log content?
cheers,
Andrea
I’ve just sent an email to your support email address with the log.
Many thanks,
Andrea
Hi Andrea,
We have not received the log via email yet. Can you please share it again.
Alternatively, I have also updated your permission, you can try attaching the log file in this thread again.
Hi Andrea,
I am sorry for late reply.
Please try the following steps to see if they can help:
If your computer has any virtual audio device, please try disabling it too since ActivePresenter doesn’t work well with some devices of this type.
Hi, I’ve solved the problem uninstalling a multimedia software that added a virtual sound card to my pc.
It was not even necessary to reboot the computer, just after the uninstallation of the sofware, Active Presenter started to work.
Many thanks for your support.
Andrea
