I have recorded a video using activepresenter and while saving I played it and it was working fine but after exporting the video, the video now dont have any audio. how can I recover the audio of the video.
ActivePresenter Version: Version 8.0.7
OS: 64-bit build.
HaiYen_Vu
(Hai Yen Vu )
July 3, 2020, 10:11am
#2
Please make sure that when you export video, you select Export Audio checkbox:
Yen
I have checked and the box is already selected. isthere any way to restore the audio. I dont have the original recording saved anywhere
HaiYen_Vu
(Hai Yen Vu )
July 6, 2020, 2:59am
#4
Hi Ramsha,
As you mentioned that you played the recording and it worked fine while saving:
So, could you please check again if your recorded project exists in the folder that you saved before?
Normally, all new projects will be saved at Project Location - the default folder path:
(To view this folder path, click on the ActivePresenter button > Preferences > General .)
In case you forgot saving your recorded project, there is no way to recover it.
